Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
27 Questions View all
Is there a glass cover on the display?
Hi, I have two insects under the glass panel. One is still walking around the other is dead.
Is it possible to remove just the glass to get them out?
I did this with my last iMac and it was easy to remove and replace. Was wondering if it was possible to do the same with my iMac M1 24"? Any help gratefully received.
2 Comments
Thank you so much for your response, I will check out the link. It seems a shame to remove it, I think I will leave it for now, they are both dead and very tiny and now at the edge of the screen.
If more appeared I think I would go ahead.
Anyway, thanks again.
Alison.
by
@Alison
Your most welcome:-)
If it still under warranty maybe tell apple about it
They might sort it out for you:-)
Thanks
by
Add a comment
1 Answer
Chosen Solution
Hi
Yes but also no
The glass on the m1 iMacs is fused with glue to the LCD however you can take it off(with the LCD attached to the glass but unless the insects are behind a part of the display that is accessible able you won’t be able to get them out sadly
If you do plan on taking the display off here’s a guide:-)iMac M1 24" Display Replacement
This guide isn’t 100% completely finished so if that isn’t much use there’s a YouTube video
https://m.youtube.com/watch?v=uBjMr--idK...
Hopefully this answers your question
If you need any help please ask
Score 2
Add a comment
Add your answer
Alison will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 128
