My Beats Solo3 wont turn on but when I charge it works
Whenever i charge it the lights show but it wont turn on. How do i fix?
Hi,
Just because it shows that the battery is charging doesn't mean that the battery is OK.
Try replacing the battery and check if that resolves the problem. Even rechargeable batteries have a lifespan.
Here's the ifixit Beats Solo 3 Battery Replacement guide that will help you to do this.
Replacement batteries are available online. Just search for Beats Solo 3.0 battery to find suppliers that suit you best.
It still doesnt work i bought new batteries and installed them and it still wont turn on but when i charge it, it just lights up like before what do i do?
Hi
First I would try forgetting it in your Bluetooth settings
Then I would try disconnecting the battery and reconnecting it by using this amazing guide
Check the on/pair button for any dirt or corrosion,if you see any clean it away with some isopropyl alcohol
If that doesn’t work it might be time for a new battery
Also make sure your charging port is clean ,if you see anything in the charging port try and remove it with some fine tipped tweezer then clean it with some isopropyl alcohol
If all of the above doesn’t work it’s most likely a logic board issue
Hopefully this helps
Any questions please ask
@J D
Can you describe what it does when it lights up?
Eg:all of the leds flash on and off or they turn red
Past 24 Hours: 16
Past 7 Days: 96
Past 30 Days: 403
All Time: 5,898
