Repair and disassembly information for the Dyson AM10 humidifier.
What does a Piezo do?
My AM10 has stopped misting, doesn't draw any water from the tank.
I am trying to troubleshoot it.
First stop is something called a PIezo, which is accessed from a panel on the bottom of the base unit.
my looks to be in poor condition but I don't know if it is the source of the problem. in fact I don't even know what it does.
it appears to have a watertight seal. so it must be sitting at the bottom of the water tray.
Score 2
Add a comment
Most Helpful Answer
@pjstock, A piezo is basically a “speaker” or more commonly known as a buzzer.
I say “speaker” because because it’s not playing sounds as a speaker, it’s only really capable of producing tones in given ranges.
You can Google “piezo buzzer” if you want to read and understand more about it :)
Score 2
Add a comment
Google it. Loads of different types.
Score 1
Add a comment
Hi. I have the same issue with my am10. Have you found a solution?
Thanks! I’d appreciate it!
1 Comment:
change it will help. I also have the same problem and find it in amazon https://www.amazon.com/dp/B0BWN3BZR8
by
Add a comment
I think in this device working the piezo element not like speaker but like object size detector. Same like in dyson vacuum cleaner. Small pieces hitting the piezo, thats generate a very small current, from this currend is calculated how many and how big pieces was catched.
Add a comment
I have the same issue . No mist anymore . I changed the piezo but it did not help
Add a comment
Add your answer
peter stock will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 48
All Time: 1,397
