The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
172 Questions View all
My X button wont work any more after using too much contact cleaner
This happened a couple weeks back when I noticed my joystick had drift, naturally I grabbed my WD-40 Contact cleaner, took the battery out and sprayed a lot on there, then I used my air duster to dry it called it a day, put the battery back in and loaded up blade and sorcery but I noticed my x button didn't work however the capacitive touch center still worked for it. I replaced the battery and let it dry for a bit but still it wont work.
Score 1
Add a comment
WD-40 is just mineral oil. The oil probably is lubricating the membrane and switch so much that it cannot read a press. To fix this I would recommend using 90% or higher isopropyl alcohol to clean away the oils. Be sure to not use WD-40 on electronics, as it is meant to lubricate and protect metal parts.
1 Comment:
The original poster said they used WD-40 Contact Cleaner, which is specifically used for electrical components.
by
Add a comment
Same. I have used WD-40 specialist contact cleaner for all my oculus controllers whenever I have a drift problem. For some of my games I use the cleaner spray every single day. WORKS WONDERS. I have however had two single controllers break directly after using the spray. One, the joystick just popped right out of a side and was disconnected from the controller! And the other incident was the A button stopped working, for good. Like you I have been unable to repair it.
*The other commenter thinks you are using actual WD-40 and not the one fore electrical parts.
Add a comment
Add your answer
oisin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 802
