The Samsung Galaxy A40 was released in April 2019.
31 Questions View all
Why does the flex cable and chargerport keeps getting damaged?
I have an A40 but the charger port or flex keeps getting damaged every time i replace it.It looks like something else is the problem does anyone have any suggestions?
4 Comments
@lms7777 what do you mean by getting damaged? What happens to your charging port? what charger are you using?
by
It will get damaged if you're rough with it. Can you upload some pictures of the part?
by
@oldturkey03 by charger port or flex cable getting damage i mean that my phone stops charging and in order to let it charge again i need to replace the part (Charger port/flex cable) thats not working well.I'm using a type C charger
by
@lms7777 that sounds like a bad charger. Use a different one and see if that makes a difference.
by
Add a comment
1 Answer
Most Helpful Answer
could be your charger connector is the cause. You haven't provide enough detail for a good answer.
Score 1
Add a comment
Add your answer
Lucarcio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 142
