Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
107 Questions View all
Broken display on MacBook Air 13" Early 2020 (MacBookAir9,1, A2179)?
Hi folks!
A small plastic bottle fell on my MacBook Air 13" Early 2020 (MacBookAir9,1, A2179) by the lid and now the display does not work properly.
To note that: (a) despite the crack visible in the attached images, the outside glass is not cracked as I can't feel anything but a smooth surface when touching it with my finger and nail; (b) I can connect an external monitor with the USB C to HDMI adapter and use it successfully.
My questions:
  1. how can I be 100% sure that the damage is in the display and not in the cables/connectors or graphic card?
  2. where would you recommend me to buy the replacement display? Ebay? AliExpress?
  3. how do I choose the replacement display? Are all at the same quality or what shall I look for?
Thanks for the help!
Add a comment
1 Answer
Chosen Solution
@nimiq, The damage you see on your screen, is standard broken panel, no question there.
You should buy the replacement from a known good vendor. iFixit has them in store.
Then you use the guide, also available on iFixit to replace the display assembly.
It’s not a very hard replacement, and as long as you take your time, are careful and you follow the guide, you should be fine replacing it :)
MacBook Air 13" (Late 2018-Early 2020) Display Assembly Image
Product
$459.99
Score 2
Add a comment
Add your answer
nimiq will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 126
