Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
420 Questions View all
Camera viewfinder is black, and freezes the system
Hello, i recently picked up a 3DS XL and when i open the camera the viewfinder on the top screen is black and after 1 minute (or swapping to inner camera) freezes the system, i could replace it but i want to make sure that it isn't a software issue before doing that. Any help is appreciated, thanks.
2 Comments
Can I do this safely even if I have a Luma 3ds on it?
by
Yep, luma won't interfere
by
Add a comment
1 Answer
Chosen Solution
The easiest way to rule out a software issue is safe mode. Boot the 3ds holding L + R + A + D-pad up (not the circle pad), and you should boot into a system update screen. Go through the prompts, and check the camera when you're done. If it still freezes, you can try a system format, which should fix anything safe mode can't. Past that, it's a hardware issue
Score 2
2 Comments:
How i holding L+R+A+D-pas up and I don't know how.
by
Add a comment
Add your answer
vex will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 50
Past 30 Days: 241
All Time: 1,918
