Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Questions View all
Can it operate without anything attached to the battery contacts?
Have to remove the battery; would be happy to operate it only while plugged in to a charger; will it work with nothing attached to the battery contacts? Have seen some guides for adding a resistor to simulate the presence of a battery, but will it work without further modification?
Add a comment
1 Answer
Chosen Solution
Without battery will not starting. You can give directy on the battery connector 3,7-4,2V and it will work, but from usb without battery not possible. Bypass with resistor is not possible, there is data communications with the battery.
Score 2
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 48
