Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Get quick access to guides, parts and answers for your devices
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
None of them helped
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 190
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
by BurtBen
No it's actually beeping like a car's blinker
by Jackson King
Could you possibly record it and add it to the post?
Not sure how?:
Adding images to an existing question
by BurtBen
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
by JnCA
