Repair and disassembly information for the ProBook 440 G7 laptop. This 14 inch business laptop was made in 2020.
1 Questions View all
Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Score 1
4 Comments:
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
by
No it's actually beeping like a car's blinker
by
Could you possibly record it and add it to the post?
Not sure how?:
Adding images to an existing question
by
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
by
Add a comment
1 Answer
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
1 Comment:
None of them helped
by
Add a comment
Add your answer
Jackson King will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 190
