Laptop power button is damaged
When I press my power button the laptop automatically start powering on and off several times and after some time it stops. If I remove the cable of the power button then this stops happening. I think my power button somehow got ultra sensitive. Sometimes it just powers on the laptop when I barely touch it.
Add a comment
1 Answer
If you remove the cable how do you turn it on? OR do you remove it when it is on?
Without more specifics, it sounds like a bad switch. These switches are not mechanical, so it is likely worn or has been contaminated by dirt or a liquid.
Add a comment
Add your answer
Muhammad Usman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 47
