The Mitsubishi MMCS NR-242 Series with SD is a car navigation system produced by Mitsubishi Motors that includes an SD card slot for expanded storage capacity. It was succeeded in 2017 by the Mitsubishi Smartphone Link Display Audio (SDA).
4 Questions View all
Replacing MMCS E-12 with W-12
Hi, I hope you can help.
My E-12 unit has a broken digitizer (screen is fine).
I found a W-12 replacement, whole unit relatively cheap.
Would it work on my 2015 Mk3 Outlander Gx5hs without coding and cable swap?
Thanks.
Score 2
1 Comment
Hi, did this swap from E-12 - W-12 work for you?
Thanks
by
Add a comment
1 Answer
Most Helpful Answer
https://pinoutguide.com/Car-Stereo-Mitsu...
If this website is to be trusted, the pinout should be the same. I would say it's at least worth a try.
Score 2
1 Comment:
Thanks a lot. In you experience, do those units require a pin code or to be ECU registered, if came from another car?
by
Add a comment
Add your answer
Toporo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 31
All Time: 250
