The Anker SoundCore 2 is a portable Bluetooth speaker featuring 12W Stereo Sound, Bluetooth 5, and IPX7 Waterproof capabilities. A perfect speaker for use inside the home, outdoors, or even during travel.
It is not charging
The speaker is not getting charged
Add a comment
1 Answer
Hi @naitikbohra
Does the speaker still work OK when the charger is connected?
If you can use the speaker but the battery is not charging it may be a faulty battery. Here's the Anker SoundCore 2 Battery Replacement guide that shows how to replace the battery.
If the speaker doesn't work when the charger is connected, have you tried a different known working compatible charger or charging cable e.g. one used to charge a mobile phone?
Use a strong light and a magnifying glass to check that the pins in the charge port connector are all there and not bent or missing, that they're all straight and parallel with each other and that there's no dust or debris in the port enclosure preventing a good electrical connection.
If everything above has been tried and it still doesn't work here's the Anker SoundCore 2 Charging Port Replacement guide that may help.
It shows how to open the speaker so that the charge port connector can be checked to see if it is loose from the board and only needs to be resoldered back on.
If everything appears to be OK then further testing would be required to find out what's wrong.
Anker SoundCore 2 Battery Image
Guide
Difficulty:
Difficult
15 - 30 minutes
Anker SoundCore 2 Charging Port Image
Guide
Difficulty:
Difficult
20 - 40 minutes
Add a comment
Add your answer
Naitik Bohra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 51
All Time: 827
