The phone comes with a 6.50-inch touchscreen display offering a resolution of 720x1600 pixels at a pixel density of 269 pixels per inch (ppi) and an aspect ratio of 20:9. Oppo A53 2020 is powered by a 1.8GHz octa-core Qualcomm Snapdragon 460 processor. It comes with 4GB of RAM.
71 Questions View all
Ketika layar di matikan,hp tidak lagi mau menyala
Ketika tombol power di tekan untuk mematikan layar,hp tidak lagi mau menyala kembali,kecuali saya restart ulang,baru bisa di pakai lagi
Google translate:
When the screen is turned off, the cellphone will no longer turn on
When you press the power button to turn off the screen, the cellphone will no longer turn on again, unless I restart it again, then it can be used again
Add a comment
1 Answer
Most Helpful Answer
Hi @yayatsugiat
Try enabling the raise to wake setting and check if lifting the phone works to turn on the screen.
Go to Settings → Convenience Aid → Gesture and Motions → Wake to raise.
If it also doesn't work there may be a problem with the proximity sensor in the phone. Is the phone in a protective case at all? If so remove it from the case and check if you can wake up the phone by pressing the power button or lifting the phone.
Score 1
Add a comment
Add your answer
Yayat Sugiat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 52
