How to disassemble the screen to replace the LED matrix cable?
How to disassemble the screen to replace the LED matrix cable? (Gigabyte Aero 16 RP86 XE4)
Update (01/11/24)
I need to disassemble the screen to replace or restore the cable
Score 1
3 Comments
Hello, You mean the led strip for display backlight?
by
Iam not 100% sure but this model should have oled display, thats mean no backlight LED is there.
by
Add a comment
1 Answer
Most Helpful Answer
The plastic frame should be glued, try to heat the display housing little bit and remove the frame... when is oled display you can use also alcohol for make easier remove the glue
Update (01/11/24)
First remove the hinge part
Score 2
Add a comment
Add your answer
Sergei Diev will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 33
All Time: 220
