Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
99 Questions View all
3ds not reading sd cards
I was in the middle of homebrewing my 3ds when out of nowhere, my 3ds stopped reading my micro sd card. It worked before, so why not now? I tried moving the files to a different microsd card, reinserting the microsd card multiple times, but alas nothing worked. I’m starting to think there’s something wrong with the sad card reader in my 3ds.
Add a comment
1 Answer
Chosen Solution
Yeah, card reader would be my guess too. Before you replace it though, there is one thing you can try. Take out the SD and put a drop or two of isopropyl alcohol (90%+) on the pins, then press the card in and out of the reader several times to try to clean the pins in there.
If that doesn't work: Nintendo 3DS 2015 SD Card Reader Replacement
Don't worry, replacing the SD slot looks like one of the easiest repairs on this thing
Score 1
1 Comment:
I think the pins just got dirty over time because when I put some isopropyl alcohol on it, it stared working again. Thanks!
by
Add a comment
Add your answer
.skyden12 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 58
All Time: 415
