Technical specifications and repair procedures for the MSI GeForce RTX 3070 VENTUS 2X OC. Released on September 11, 2021.
1 Questions View all
GPU Heatsink Thermal Pad Thickness?
Does anyone know the correct thermal pad thicknesses for these cards? I have found conflicting information and haven't been able to find firm answers, since there are so many variants. Even going directly to support, their response doesn't seem accurate to what I found when I removed the heatsink.
Add a comment
1 Answer
If you measured the thickness and accounted for probable compression you should be able to relate that to an available item. Personally, I would attempt to use thermal paste, but there might be a voltage diff across it. I'm not sure why pads are used in place of paste.
Add a comment
Add your answer
Jamus will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 89
