Nokia G22 keeps rebooting at random moments
My Nokia G22 keeps rebooting at random moments. Sometimes it reboots while I'm using the phone, sometimes when I'm not using it. As far as I can tell, all my apps are up to date and I have enough memory and storage available (usually >1GB RAM and >50GB storage). As far as I can tell it doesn't happen when I'm using any specific apps. A reboot also occured when the phone was in safe mode.
Sometimes it reboots five times in an hour, at other times it can go days without going through a weird reboot.
When it reboots, the screen freezes for a second and then goes black for about a minute. Then it quickly boots back up, without showing the android logo or playing the Nokia jingle like it would after a normal boot or reboot.
The unlock screen reads "Need pin after rebooting", so the phone does recognize it as a reboot.
I also sometimes feel it buzzing a few times in rapid succession before it reboots, similar to the buzz it makes when unlocking with the fingerprint sensor.
Another issues I have experienced is that sometimes phone keeps hanging at the login screen. I enter mij PIN and press enter, but the phone does nothing. I can see the button being pressed (multiple times) but it doesn't unlock.
Any ideas what it could be? Hardware or software?
EDIT: a full factory reset fixed all problems!
6 Comments
Hi @leadstripes,
Does it do this with the charger connected?
To clear the cache you have to do it for individual apps.
Go to Settings → Apps → select desired app → Storage → Clear cache.
by jayeff
@jayeff I think it also does it when the charger is connected. After leaving my phone charge overnight, I've woken up to the "Need pin after rebooting" message
by leadstripes
@leadstripes
For the sake of elimination, enable the data saver setting and check if the problem occurs.
Go to Settings → Network and Internet → Data Saver.
This should prevent any background internet connections unbeknownst to you from happening that may be overloading the hardware, causing it to shutdown and then restart.
As I said, just trying to eliminate things.
Once you can make the problem happen (or stop) you're halfway there to finding out what's causing it. ;-)
by jayeff
I've turned it on, no to wait and see if anything happens (or not). Funnily enough, no reboots have been happening today at all.
by leadstripes
Well, it just rebooted with data saver on. So I guess it wasn't that. I was using a podcast app for the first time today, so I'll see if that might be the cause
by leadstripes
Show 1 more comment
