Repair and disassembly guides and support for dish washing appliances.
720 Questions View all
Draining the water after the cycle is not working properly
My draining hose is around half meter from the ground , and my dishwasher gets a fault message “the draining “ nothing wrong , looked at the pump , took it out it was rusty and I just bought a new one , installed and it does the same , I could hear the pump but it only takes water if I put the draining house close to the ground , if I lift it up a little bit then it stops, what could be the problem here ?
My dishwasher is Miele G1170 VI , checked also the hoses inside , found some rubber sealings missing , mounted some teflon tape but nothing helped.
Add a comment
1 Answer
Sounds like the pump can't overcome the hose height. If the "pump" is placed into a housing, IE not self contained with an in/out port, The housing may be worn so that it can't build up pressure.
Add a comment
Add your answer
Moise Cristian will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 18
