2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Keys Not Working Correctly
A while back, my left shift key stopped working. It feels like it's slightly pressed down and won't fully bounce back up. Regardless of how many times I press the key, the shift function does not work.
Recently my left "a" "s" and "option/alt" keys are intermittently not working correctly. I need to hit the key a few times to get the letter to show up, often resulting in repeated letters: "aaaa". The "option" key is starting to act like the shift key and feels like it's not fully bouncing back up.
I haven't spilled anything on it, but my battery does need replacing. I read that the battery going bad is a possibility, but the battery isn't swollen or anything. I haven't gotten to it yet because I use my laptop almost 24/7 and don't really have the time to swop it out and have something potentially go wrong. But the keys not working is a real nuisance. I pried off the shift key to see if there was anything blocking it, just some dust, so I cleaned it, and put the key back, but it is still not working. Any ideas besides dust that could cause the keys to intermittently not work?
Add a comment
1 Answer
It is almost a 10 year old model, things do wear out in time, the keys that have stopped working are in the most used catagory so it is likely that a keyboard replacement is in order, there are good guides on here on how to do that yourself, just needs some patience and a little courage and anyone can do this :) The Batteries are quite easy to change. 2015's are great Macs and some would argue they are amongst the best models apple ever made, I am using one myself!
Add a comment
Add your answer
Dorothy Phillips will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 96
