The V2 Controller comes in different Generations. You’re looking at Generation 4.
10 Questions View all
Button inputs mixing and matching
I was playing an online game and got so angry that I threw my favourite controller, 5 years old, on the floor full force. I regret it terribly.
I've opened her up many times to change worn out rubber padding. I opened her up again, saw nothing wrong except a broken metal weight on the lower left. Put her together. I use her on PC, so i checked the inputs and they were fine on windows. I check them in game and button inputs are mixing, I press SQUARE and the results with be SQUARE TRIANGE. Or I press R1 and Ill get R1, CIRCLE and CROSS output results. I suspect the green motherboard inside is faulty or needs a replacement? What do think?
Add a comment
1 Answer
A broken metal part might have caused colateral damage to the PCB that would require careful inspection with a glass to find.
Add a comment
Add your answer
Athi Musoke will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 31
