Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
376 Questions View all
Where can I find a replacement gasket?
I was following this guide and am having trouble finding the Gasket mentioned. Where are we supposed to get this 'gasket' from? I don't see it here.
Add a comment
1 Answer
Most Helpful Answer
Hey there, the only gasket mentioned is the one for the loudspeaker, which can be purchased here. Unless there is another gasket that you're referring to.
Replace the adhesive foam gasket that fits between the loudspeaker and the speaker opening in the rear case compatible with iPhone XS Max. This gasket helps seal liquid and dust out of the device. Image
Product
iPhone XS Max Loudspeaker Adhesive Gasket
$0.99
Score 1
Add a comment
Add your answer
pvillave will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 9
