Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
78 Questions View all
Low temperature battery issue
I recently been getting this issue, Pressing on the back where the wireless contacts connect usually fixes it, Now it just won't charge at all, Any good places to find a replacement wireless charging pad for it?
Add a comment
1 Answer
@chriscodm you are not telling us if it still charges by wire. I would suggest a new battery as well. Wireless Charging Module is available at many places including on here
Update (03/26/25)
@chriscodm If a new battery and the charging module do not yield any results, follow the Samsung troubleshooting flowchart for the not charging (both wired and wireless)
Use the Samsung Galaxy S10 Component Layout and your PDF readers search function to locate the component to check (i.e. C8144) on your main circuit board. Measure the values listed and replace/repair as needed. This is for the charging only. If you look at the flowchart you see that they have one IC in common and that is U8031. Samsung part number for that is 1203-009156 and it is referred to as the Power Supervisor IC the actual IC is a MAX77705C and it is readily available at many online places. Probe around that one.
1 Comment:
It doesn't charge in either way, both wired and wireless, but thanks for finding a replacement part!
by
Add a comment
Add your answer
ChrisCodm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 29
All Time: 29
