Air Filter
1 Answer 0 Score |
High Fan Speed and Noise (overspeed?) |
6 Answers 5 Score |
Loosing power after 30 seconds of use? |
5 Answers 0 Score |
The unit shuts down after 15 sec. And I unable to buy the Thermal Fuse |
1 Answer 0 Score |
Two items work only 30sec then switch off. |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Information
The Black and Decker Pivot MAX is a cordless hand-held vacuum with a 20v Lithium-Ion battery. This can be identified with the Pivot Lithium 20v max labeled on the side in blue letters. It has a pivoting nozzle with Black and Decker labeled on the top. The model number is BDH2000PL and can be found underneath the pivot lock button, behind the dust bowl. It includes and battery charger for the 20v Lithium-Ion battery.
This vacuum can be used in various places with the pivoting nozzle and its small size. There is also a crevise tool that can extend and retract for hard to reach places. The bagless dirt bowl has 42% greater capacity than the original Pivot vacuum, and a side door for emptying the dirt.
