Battery
1 Answer 0 Score |
I do not have brake it rolls freely after you let off trigger |
1 Answer 0 Score |
dewalt dcf 885 switch assembly |
1 Answer 0 Score |
new brushes for the DCF885? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The DeWalt DCF885 is a yellow and black, compact impact driver. It was introduced in 2012 as part of the DeWalt line of 20 volt powered hand tools. Since its debut, it has been very well received across many review sites.
The tool is of a compact design. It weighs only 2.8lbs and 5.5 inches long, perfect for fitting in tight spaces. It uses a 20-volt lithium ion battery. It is a ¼ inch impact driver. It spends up to 2800 rpms and a max torque of 117ft-lbs. The DeWalt DCF885 is a popular tool for home repair because of its versatility and affordability.
Identification
This impact driver is black and yellow. The model number DCF885 can be found on the side of the tool.
