Battery Door Hinge
1 Answer 0 Score |
Can I recover deleted photos from a digital camera? |
No Answers 0 Score |
Why won’t my camera turn on |
Battery door will not stay shut tab is broken off |
It's not coming on |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting:
For additional help on the Fujifilm FinePix AX655, check out the device's troubleshooting page.
Background and Identifications:
The Fujifilm FinePixAX655 is a digital camera that was designed and manufactured by Fujifilm. This camera is considered a good entry-level camera that will allow people at any skill level to take expert-level photos. The Fujifilm FinePixAX655 is a 16.3 megapixel, CMOS sensor-enabled, and 5x optical zoom digital camera that was introduced to the market in July of 2013. The model number is located on the bottom of the hinge door where the batteries are located. With the CMOS sensor, this allows the camera to take pictures while using a lower amount of power than normal. The camera has fast autofocus and fast start-up speed. The usage of AA-batteries makes the camera convenient. This camera weighs 5.2 ounces and has dimensions(LxWxH) of 3.8x 0.80x 2.20 inches, so it is easily portable. The camera also utilizes a 2.7 TFT LCD screen that will allow you to frame the shot perfectly.
Specifications:
Camera Type: Digital Camera
Color: Black
Effective Pixels: 16.3 MP
Sensor Type: CMOS
Display Size: 2.7 inch
Touchscreen: No
Weight: 348.71 GM
Manufacturer part number:16327943
Focal length: 33-165 mm
Optical zoom: 5x
Assembled product dimension(LxWxH): 3.80x0.80x2.20inches
Battery: AA, NiMH, Lithium-Ion, InfoLithium, Lithium
