Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The HP Pavilion 17-ak008cy is a fairly larger laptop. It has an HD Touch Screen with a 7th generation AMD A9-series Micro Processor. It comes in two colors, Silver and Black. On the inside, there is sinusoidal wave design of the faceplate of the key board. It is intended for a personal laptop for everyday purposes. This computer is not made for video games or calculations which require a high amount of power. The touch pad is also off center compared to the rest of the screen. The power cell is easy accessible since it must be replaced frequently due to it is not being a high power battery.
Identification
With a 17” display it sits with the dimensions of 41.5 cm x 27.8 cm x 2.46 cm. On one side there is an USB and an SD card reader. On the other side are two more USB, an HDMI, and a Ethernet input. For better identification a serial number and bar code can be located on the back side of the laptop or in the battery compartment like other HP Pavilion 17 laptops.
Technical Specifications
  • Micro Processor - AMD Dual-Core A9-9420 APU
  • Memory - 4 GB DDR4-1866 SDRAM (1 x 4 GB)
  • GPU - AMD Radeon™ R5 Graphics
  • Hard Drive - 1 TB 5400 rpm SATA
  • Optical Drive - DVD-Writer
  • Display - Display size (diagonal)">43.9 cm (17.3")
  • Keyboard - Full-size island-style keyboard with integrated numeric keypad
  • Pointing Device - Touchpad with multi-touch gesture support
  • Network Interface - Integrated 10/100/1000 GbE LAN
  • Expansion slot - 1 multi-format SD media card reader
  • External Ports - 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
  • Dimensions - 41.5 x 27.8 x 2.46 cm
  • Power Supply Type - 45 W AC power adapter
  • Battery Type - 3-cell, 31 Wh Li-ion
  • Audio Features - Dual speakers
  • Operating System - Windows 10 Home 64
  • Software Included - McAfee LiveSafe™
Additional Information
Click here for HP Support Page.
This page will include detailed information on the specifications and parts lists of the product.
Click here for screen replacement procedure.
this link will bring you to a screen replacement tutorial.
Click here for a fan cleaning tutorial.
this link will take you to a video for routine cleaning.
Andrew Silva
497 Reputation
3 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 1,503
