Blade
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Ryobi CSB135L is an electrical circular saw released on April 6th of 2013. The Ryobi CSB135L’s features are highlighted by a 14 amp motor, a 7-¼ inch blade diameter, and an internal laser offering accurate and precise cuts.
The Ryobi CSB135L is very similar to other electrical circular saws across multiple brands including Ryobi itself. Ryobi offers a very similar saw in the Ryobi CSB125. The two differences between the two saws are that the CSB135L offers an internal laser for precision cutting, and a 14 amp motor compared to the CSB 125’s 13 amp motor.
The Ryobi CSB135L has not been issued a large-scale recall. The saw is also very well reviewed across multiple store sights for its affordability and reliability for smaller projects. However, some issues mentioned include issues with the laser, and issues with guard of the blade. Other than these issues the saw is reviewed very favorably.
Identification
The Ryobi CSB135L is a compact lightweight circular saw. You can find the blade of the saw, along with the blade guard and laser in and around the metal blade housing. The trigger to operate the saw can be found under the handle of the saw. To properly identify the device look on the motor housing for product name and model number.
Technical Specifications
Dimensions:
- 7.5 x 12 x 9.5 inches
Weight:
- 7.35 pounds
Power:
- 14 Amps
- 120 Volts
Color:
- Green
Cord Length:
- 6 feet
Speed:
- 5000 RPM
Blade:
- Length: 4 inches
- Number of teeth: 20
Cutting:
- Depth at 90 degrees: 2.438 inches
- Depth at 45 degrees: 1.875 inches
Material:
- Saw: Acrylonitrile Butadiene Styrene (ABS)
- Blade: High Speed Steel
Source:
