Adapter Audio Jack Board
2 Answers 4 Score |
Both ears broke off. |
1 Answer 4 Score |
How can I stop right side creaking |
1 Answer 1 Score |
How do I replace the headband? |
1 Answer 0 Score |
Why is my microphone not picking up sound? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Turtle Beach Ear Force XO Seven is an over-the-ear gaming headset manufactured by Turtle Beach Systems and was released in 2013. The headset is compatible with the XBox One and mobile platforms. The purpose of the headset is to create a more immersive gaming experience. The Ear Force XO Seven can connect with the XBox One wirelessly using the provided XBox One Audio Adapter. A user can also chat with friends through Skype or XBox One LIVE.
The headset weighs roughly 5 lbs and is painted black with a green accent on the earpieces. There's a leather cushion with stitching on the arc. You should be able to adjust the size of the headset by pulling the cushion away from the earphone. There are two jacks (audio and microphone) on the bottom of the left earpiece.
Identification
There are two previous generations of this headset, the XO One and the XO Four. The XO One & XO Four doesn't have memory foam padding, pleather ear cuffs or the customizable side plates. Also the XO Seven is much bulkier than the other versions. Above the left earpiece, there is a model number which should be TB300-2219-01.
Specifications
Package Contents
Guide: Quick Start Guide
Sticker: Turtle Beach Sticker
Cable: Headset Breakaway Cable
Headset: Ear Force XO Seven Headset
Mobile Device Cable: Mobile Adapter Cable with In-Line Mic
Microphone: Removable Mic Boom
Audio Controller: Xbox One Audio Adapter
Headset
Speakers: 50mm diameter speakers with neodymium magnets
Frequency Response: 20Hz - 20kHz
Weight: 12.2oz/346g
Headband/Earpad Material: Synthetic Leather Headband and Earpads with Memory Foam Cushioning
Microphone Design: Removable Uni-Directional Microphone
Earcup Design: Around-Ear (Closed)
