MacBook Pro 13" Unibody Mid 2009 Battery Replacement
Introduction
Go to step 1Use this guide to replace an old or faulty battery and revitalize your MacBook Pro. If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Show more…
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
Well . . . I ain't never done nuttin' like that, before!
Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
Am I allowed to cry?
Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
IFIXIT - IDIGIT!
HAHAHAHAHAHAHAHAHAHA.
That was a brilliant read.
Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
Glad your Mac repair journey worked out.
Cary B -
Remove the following tri-point screws securing the battery to the upper case:
One 5.5 mm tri-point screw.
One 13.5 mm tri-point screw.
Mine does not have triwing screws.... They have 5 points but none of my torx stuff works? What is it? I have one of your sets of 20 or so pieces and nothing works.....
pentalobe. its an apple specific driver to keep you out. The bottoms of the airs use this as well. You can fid one on eBay
Where in the world can I find a tri-point screw bit?
Which size trilobe screw bit do I need to buy? (Just bought one and it is too big, %#*@ it.)
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
use two spudgers, one of each side of the connector.
I used the nails of thumb and pointer finger simultaneously - worked pretty fine
Lift the battery out of the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Did everything correctly, but now the battery doesn't charge. Do I have to do something in particular to make it work now that's installed? Thanks
I am answering a 2 year old post but this is for those who may have the same or similar issue in the future.
When I was putting the battery connector back on that it didn't sit flat against the board before I put pressure on the top of the connecter to press it back into its socket. I then took time to examine the battery connector socket and saw it consisted of long thin vertical pins. I deduced that if the battery connector was not aligned correctly to the pins on the motherboard then it may be very easy to bend one or more of the pins in a way that they wouldn't mate up with the opposing female part on the connector. That sure would cause a battery charging issue. If you feel too much resistance when pressing the connector back into the socket then stop and make sure it is all aligned correctly. I know, not easy with the size, the black connector and black socket. A spudger can be used on the battery side of the connector to raise it to a level position prior to applying pressure to the top of it.
I too encountered the same problem. After resetting the SMC (http://support.apple.com/en-us/HT201295), it resolved the problem.
I put the battery in ok, then placed it on charge and tried to start it. It didn't like this at all, letting out evenly spaced unfamiliar beeps. I felt sure i had done something terrible. I held down the start button and turned it off. Half an hour later I turned it back on, upon which it sprung back to life, much to my relief. The battery needed to be charged before starting it seems.
Yes, you should charge your battery before using.
Cary B -
One important hint is missing: Don't tighten the two battery screws too much! I did, causing the new battery to press against the trackpad from below, thefore my trackpad wouldn't click well anymore. After opening the MacBook Pro again and loosening the two battery screws a bit, my trackpad is working well again.
732 other people completed this guide.
51 Guide Comments
My laptop wouldn't believe the battery was new until I reset the SMC as well ( http://support.apple.com/kb/HT3964 ).
Perfect! I didn't want to wait for the Tri-wing screwdriver to ship, so I gave it a try by wedging a FH 1 in between two of the wings. It worked well to unscrew, but you must be very careful when resetting the screws that hold the battery. If you get them started with your finger (a little pressure with your thumb pushing straight down will get the job done) then you can do a few final turns with the FH 1. If you try to start resetting the screws with the off-center-FH1-workaround, you will strip the screw! Keep the screws centered and don't force anything.
My local Apple Store wants $179 plus tax to change this battery, AND I have to leave my laptop for "a couple of days." This is one store that clearly doesn't get it (Cherry Creak Mall, Denver). Thus, a DIY fix is mandatory... but, they won't sell just the battery.
iFixit sells the battery you need for $119 (http://www.ifixit.com/MacBook-Parts/MacB...), and once you get it, doing the replacement shouldn't take more than 30 minutes, even if you've never done a repair like this before.
I followed the instruction carefully and the battery works great. However, now my trackpad won't depress in all but the lower right corner. Anyone know how to fix this?
I found out the battery tab screw holes are slightly misaligned by about 1/2 mm. This causes the battery to wedge in too tightly to the track pad which is directly above. Using a small drill bit I moved the holes slightly allowing the battery to move slightly toward the center of the laptop. This took the pressure off the track pad. Also I took the clear plastic covering off as well. It works great now.
john -
The longer tri-wing bolt won't fit properly into the new battery I got through ifixit. The hole is too small and appears the wrong shape. It seems like this was the case with the old battery too, as there a crack in the corner near the hole where someone had to widen it. In the end I used the tip of a metal knitting needle (the sturdiest thing of the right size I had to hand) to widen the hole slightly, causing a similar crack. I guess since the bolt's thread is only at the tip where it enters the metal laptop casing this shouldn't affect how securely the battery is joined.
I had no joy with a 00 Phillips either, but this was probably due to the crappy quality of my socket set.
I added this battery on my Macbook Pro 2009 edition. I still only get 2 hours of online video (youtube or netflix). is that normal? And the Maximum Capacity of my battery is 93% at arrival??
Any tips to increase the battery life of my laptop? I don't mind going back to mavericks or earlier versions..
Success! My mid 2009 MBPro is still going strong thanks to this battery change. HDD upgrade to SSD is due soon... Thanks iFixit.
The new battery will not charge. All the lights are flashing. I tried resetting SMC and reinstalling the battery but nothing worked.
If you buy this battery new from OWC (macsales), they include--for free--the two screwdrivers you will need. Got this battery today for 99.00, installed it myself based on this instructional in 10 minutes. And I have never opened a macbook before, first time. The main things: don't lose the screws, most of them are incredibly tiny (I lost one when dusting with microfiber), don't forget to put the screws back on battery housing, and be gentle and patient when removing small, semi-rigid battery wire cable. Best wishes.
Thanks a lot for a descriptive guide. Battery was replaced like a breeze.
I bought a new battery from ifixit.de, was around 100€. I have to say I'm a bit dissapointed, charge is nowhere near full it's around 3500, battery barely manages an hour and a half. Have to say it was not worth it. Cocconut battery says it's 3,1 years old and lost around 20-25% of it's original capacity. I feel I got robbed for 100€
Thank you SO much.
This was easy and worked very well.
I used a battery from Duracell Direct, which cost £50 (inc. delivery) which has a one year warranty.
I took the opportunity of cleaning the inside while it was open, using a soft sable-hair paintbrush, to lift the dust off the circuit board, and a microfibre cloth on the inside of the case.
It read 46% charge when first put in , (which may not be correct until it has calibrated itself) which dropped on use to 18%, and has recharged happily and just now it has reached 100% - brilliant!
Thanks again,
Kate
The date of the above post is 28th October 2016,
Kate
I upgraded my macbook pro 13" mid 2009:
replaced optical drive with 250GB SSD.
replaced 2x2GB RAM with 2x4GB.
replaced old battery..
Things work, except the fan never slows down and makes a lot of noise.
The fan start at full speed as soon as I click the power button, even before the screen lights up.
Please help.
Also the bluetooth and camera stopped working :(
Did you solve the fan problem? Otherwise perhaps try "smcFanControl"?
Thanks for this guide!!
Very helpful and easy process. Go the local laptop service store if you cannot get the battery screws to open, as it's not easy to get the screw driver for it
Great and easy. Well done
Will the 2009 battery and replacement guide work for a 13" unibody from late 2008?
Check your model carefully—I don't think any 13" unibody MacBook Pro was made in 2008. You might be thinking of the regular MacBook, in which case the guides you are looking for are right here.
I did the following:
Replaced old battery.
Replaced 2x2GB RAM with 2x4GB.
The step by step works precisely. I see improvements in speed and holding a charge. Thanks W Galan and 7 other contributors.
Decided to hold off on replacing the track pad until I had successfully replaced the battery first (my first project). I didn’t realize my trackpad not working could be because of battery swelling, but I’m pretty sure that is what happened. My gratitude is overflowing. And I can use my trackpad again. :)
Thanks!
Any tips on what to do with an old battery? Landfill? Recycle it… somewhere?
@abolsen It should absolutely get recycled! You can’t just drop it in the bin though. You can find some guidance on finding a recycler here. Depending on where you live, you may also be able to take it to big box store as a lot of them freely accept batteries for recycling (OfficeMax, Staples, Best Buy, etc.).
I did the replacement of the battery on the my wife’s Macbook Pro 13” Mid 2009 and the guide was really useful. Perfect and easy.
The holes on the battery for the battery mounting screws may not line up exactly with the threaded receptacles on the MacBook chassis. You may have to exert some pressure on end of the battery to get the holes to line up. Recommend installing the longer screw (adjacent to the memory chip) first.
Worked like a charm! Took a little more than 5 mins, but who’s counting? My old battery had more than 3,300 days on it and although it still worked fine, after almost 10 years of service, probably better to go ahead and replace it. Thanks for the instructions!
I changed the battery, the HDD to a SSD and the RAM from 2GB to 6GB (or 8, can't remember). When I try CMD + R it doesn't go into OS recovery. When going into diagnostics (holding D when booting) and start the hardware test it gives me a error code: ‘4SNS/1/40000000:TB3T-128.000’.
When Googling this error I find that this is a system sensor for the battery temperature that is not working. Did I buy a broken battery? Please help!
Changed the battery and increased the RAM. Super easy. Thanks for these easy to follow guides!!!
Replacement done on my Macbook Pro 13” Mid 2009 & the guide was really useful. Super easy.
Battery was 57% charged with Cycle Count of 1 / Max 5800 mAh. Thanks for the instructions!
Piece of cake. Thank you for the terrific instructions and parts. The battery replacement was quick and easy and my computer runs great. I thought that I was going to have to replace the trackpad, but the swelled battery must have been interferring with it. It works great now.
Merci beaucoup pour toutes les explications, j’ai réussi à changer ma batterie sans aucun souci. J’espère que le prochain tuyo sera de comment nettoyer l’ordinateur à l’intériorité car quand j’ai l’ouvert, il était plain de poussière. Donc, j’ai rien touché, seulement la batterie. Je suis contente. merciiiiiii infiniment.
Have spent over an hour trying to get the long trip tip screw to seat and screw in
Tried screwing in the short one first and that didn’t work.
Any advice? will the battery stay put if we don’t use this screw?
Now after over 2 hours of trying to screw in the long tri tip screw which holds the battery, I decided to put the old battery in place to see how it screwed in. IT WENT RIGHT IN!!!. So eyeballing some more, we can see that the plastic screw hole on new battery DOES NOT LINE UP with that screw hold. Comparing the new and old battery back to back they appear exactly the same size etc, but obviously not. The old battery will lay right over the screw hold (without securing the battery under the 3 cover tabs) but the new battery hits on the side and top when trying to lay it down directly on top of the screw hole.
My question now is, can I secure the new battery with just the short tri head screw or is that absolutely a no no. Thank you anyone in advance for advice, suggestion, answer.
Did a combination of the hard drive replacement cable, a hard drive swap to SSD, and battery swap. Super easy. Great instructions! Thank ya!
HELP HELP Just received battery from my mid 2009 Macbook pro 13” , & it went i without a hitch Now it seems that I can’t turn it on, or else the screen will not come on The keyboard is lighting up fine any advice or information would be great
Successfully replaced my Macbook battery on my own using this guide. I just bought a replacement battery from ebay for $39. Thanks for the helpful guide.
I changed the battery on my MacBook Pro mid-2009 and it is not detected. I put the old battery back (which still worked) and now it is not detected either! I tried to reset SMC but it's not working. Any idea ??
I’m also getting the same error, it seemed to recognize it a bit by using it for sleep mode, but the point of it that gets the MacBook working without the cable, seems to not work.
Thanks for this very helpful tutorial! Without having any experience, I could easily change the battery within a few minutes and it has immediately worked. BUT one important hint is missing: Don't tighten the two battery screws too much! I did, causing the new battery to press against the trackpad from below, thefore my trackpad wouldn't click well anymore. After opening the MacBook Pro again and loosening the two battery screws a bit, my trackpad is working well again. Besides changing the battery, I have upgraded the RAM from 4 to 8 GB and replaced the HDD with a 500 GB SSD and my MacBook Pro 13'' mid 2009 has been working well for 14 years, now with Linux Mint 21.1.
Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
David Kilbridge - Reply
Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
mastover - Reply
I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
adlerpe -
That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
joyitsjennie -
Great idea and one I use often
Thomas Overstreet -
Excellent idea! Thanks for sharing it here.
Laura Sharkey -
I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
valentinedhdh - Reply
I use a magnetic mat and place the screws in order on that :)
Cary B - Reply
How to tell all screws apart?
Spudgeboy - Reply
