Melitta Caffeo Solo brewing unit maintenance
  1. Melitta Caffeo Solo brewing unit maintenance, Brewing Unit maintenance: step 1, image 1 of 1
    • Remove the brewing unit from the device.
  2. Melitta Caffeo Solo brewing unit maintenance: step 2, image 1 of 1
    • Take off the cap covering the screwhole in one corner. The cap ensures a better fit of the brewing unit.
    • Note: some versions of the brewing unit do not have this cap.
  3. Melitta Caffeo Solo brewing unit maintenance: step 3, image 1 of 1
    • Remove the single black Torx T10 screw fixing the opening handle.
    • Using a certain amount of force pull the opening handle out of the guidance near the red button.
    • Rotate the handle 90 degrees counterclockwise, then lift it off.
  4. Melitta Caffeo Solo brewing unit maintenance: step 4, image 1 of 2 Melitta Caffeo Solo brewing unit maintenance: step 4, image 2 of 2
    • Unclip the upper protection panel, then remove it by lifting it up.
  5. Melitta Caffeo Solo brewing unit maintenance: step 5, image 1 of 1
    • Remove six Torx T15 screws holding together the brewing unit. The screwholes are rather deep.
    • Lift the upper half of the brewing unit up.
  6. Melitta Caffeo Solo brewing unit maintenance: step 6, image 1 of 2 Melitta Caffeo Solo brewing unit maintenance: step 6, image 2 of 2
    • The inside of the brewing unit ist exposed. You can see:
    • The upper piston and its gasket.
    • The funnel for the coffee grounds
    • The lower piston.
    • The hold-down clamp
    Hi, Thank you for your howto. It is very detailed and helpful.
    There is another seal in the lower piston. it seems to be a lip seal.
    I searched and couldn't find a remplacement for that. do you know where I can buy it?
    Many thanks
    Iklef Mallem - Reply
    Do you mean this one? See the comments in step 9.
    VauWeh -
  7. Melitta Caffeo Solo brewing unit maintenance: step 7, image 1 of 3 Melitta Caffeo Solo brewing unit maintenance: step 7, image 2 of 3 Melitta Caffeo Solo brewing unit maintenance: step 7, image 3 of 3
    • Remove the funnel.
    • Rotate the lower piston counterclockwise and lift it off.
    • Lift off the upper piston. There ist still a hose connecting the piston to the coffee outlet. In top there ist also the downholder of the brewing unit.
    • Sometimes this downholder ist torn and the coffee leaks out of the brewing unit and does not fill your cup. Inspect the downholder for cracks. You can fix this using a special repair kit.
    Anyone seen the repairkit somewhere?
    Hugo van der Kooij - Reply
    we have taken the piston out to replace the gasket, and noticed that 2 of the 3 return springs within the housing surrounding the piston are broken and offset. can we buy these springs as spare parts anywhere? many thanks
    Hannah - Reply
    Until now I didn't find these springs as spare parts. You already have the brewing unit, so I would buy a used one (e.g. from ebay ) and take the parts from it. The brewing unit could be from an older Melitta, Bosch, Siemens or Nivona.
    VauWeh -
    Was ist dieser Niederhalter? Wo kann dieses Teil reißen, kannst du mir kurz einen Hinweis geben. Bin mir unsicher auf welches Teil zu verweist. Evtl. könnte man es im Bild farblich markieren. Danke!
    kapott - Reply
    Habs jetzt in Bild 5 grün markiert. Es ist wie eine Brücke über dem oberen Kolben. Er trägt auf der Unterseite eine kleine Gummidichtung (kann auch kaputt gehen), die verhindert, dass der Kaffee oben über dem Kolben rausfließt (sondern zum Kaffeeauslauf nach vorne), wenn der Kolben ganz oben ist. Der Riss kommt recht häufig vor; er ist ziemlich unauffällig, du erkennst ihn, wenn du versuchst den Niederhalter zu verbiegen. Eine mögliche Quelle habe ich ja oben am 3.Okt.2020 angegeben.
    VauWeh -
  8. Melitta Caffeo Solo brewing unit maintenance: step 8, image 1 of 3 Melitta Caffeo Solo brewing unit maintenance: step 8, image 2 of 3 Melitta Caffeo Solo brewing unit maintenance: step 8, image 3 of 3
    • Remove the hose connecting the upper piston and the coffee outlet.
    • Remove the upper piston.
    • Remove the Torx T20 screw from the screen of the upper piston.
    • Take off the cover of the gasket and the gasket.
    • Replace the gaskets of the upper piston, the coffee outlet and water connector.
    • The lip of the piston gasket must point towards the pressure, i.e. downwards.
    • Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
    I have no coffee/water coming tru the outlet of the upper piston, i can see water runs into the piston chamber but nothing goes tru. I have changed the drain valve without luck - Any clue of what my problem could be?
    Christian - Reply
    Check for a tiny crack in the downholder .
    VauWeh -
    Just checked the downholder, it looks fin also without cracks.
    next step?
    Christian - Reply
    Well, are you sure that the issue is really with the brewing unit? I would ask someone if they could borrow a brewing unit for testing. As many machines are produced by the same factory and are equally designed (Eugster in Portugal) brewing units from Nivona, Bosch and Melitta will also fit.
    VauWeh -
    Das Sieb am oberen Kolben ist eine Torx T10 Schraube.
    Jarling - Reply
  9. Melitta Caffeo Solo brewing unit maintenance: step 9, image 1 of 1
    • The crema-valve is located in the interior of the upper piston. It is fixed by two Torx T10 screws.
    • Remove both screws. Lift off the valve. Inspect it and clean it.
    • Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult.
    • Lubricate all sliding parts with food-proof silicone grease. Verify the smooth operating of the brewing unit.
    Nice article, I’ve renewed the lip seal in the brewing unit but I still don’t get even a drop of coffee in the cup, it all goes in the drip tray.
    I have dismantled the brewing unit complete and suspect the lower piston seal to be the problem as it doesn’t provide any “resistance” or tight fit.
    You say; “replacing is difficult”, but no instructions. Could you please provide a link?
    Many thanks in advance.
    Kim Conrad Jorgensen - Reply
    You can buy the O-ring here. There is a cover glued over it. You have to break it out and reattach it later with a special food-safe adhesive. It's tricky and often doesn't work. I avoid this repair and try to get a used brew chamber. Are you sure the downholder and its seal is ok?
    VauWeh -
    And: Did you have a look to the drainage valve?
    VauWeh -
    Hi,
    Thanks for the instructions.
    There was a round spring that fell of when I dismantle, do you know where this should be?
    I think it is the gray circle in step 6 picture, down to the left (8th o´clock) from the yellow circle?
    Claes K. - Reply
    Yes, there is a helix spring. Just put it in.
    VauWeh -
    Hello. I managed to replace the o-ring for the piston, I mean taking out and installing the new one, using a tool from this kit: YT-08429 .
    Ursan Andrei - Reply
Follow the steps in reverse order to reassemble your device.
12 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
247,732 Reputation
281 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,752 Guides authored
4 Comments
The brewing unit in my Melitta Avanza Series 600 (which is apparently identical) was completely stuck inside the machine, and the only way I could get it out was to follow this guide. Unscrewing the accessible side of the brewing unit gave me the necessary access to finally get the brewing unit unstuck and out of the machine. The cap mentioned in step 2 was a bit hard to get out with the brewing unit still inside the machine, but by first unscrewing all the other screws to loosen the side a bit and then using some force, I finally got it off without breaking it.
Note that I also had to reset the main gear position to get the brewing unit back into the machine, which on my machine was performed by pressing the single + double espresso front panel buttons for 2 seconds.
The reason why it was stuck? 100% my fault. I turned the machine off in the middle of a cleaning cycle when I realised I forgot to insert a cleaning tablet, and then tried to get the brewing unit out and ... yeah ... don't be an idiot like I was, do NOT attempt to take the brewing unit out while it's in "engaged" mode, unless you too wish to follow this guide for that reason. 😉
Fixiepixer - Reply
There is also a more bloodless way: open the left side, find the cables to the motor. Connect 12 V DC, et voila....
VauWeh -
Hello. Congratulations for the info. Can you tell me what is the service interval or when is necesarry to replace the gaskets inside the brewing unit, is there a simptom that appears in time ? I have a Melitta Caffeo Solo&Milk that I bought(new) two years ago. Thank you .
Depends on the number of prepared coffees. After two years it might be necessary, especially when the used coffee grounds is too moist. The procedure is simple and the parts are cheap, so it's better to have one more than too few.
VauWeh -
Past 24 Hours: 7
Past 7 Days: 61
Past 30 Days: 364
All Time: 29,488
