Help
iPad Wi-Fi Display Assembly Replacement
Editing Step 4 —
Notice: You are now editing a prerequisite to the guide you were just viewing. Any changes you make will affect all 11 guides that include this step.
Step Type:
Drag to rearrange
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Pry carefully and gently—if you feel resistance, stop and pry at another spot.
