Help
Apple AirPort Express Base Station Power Supply Kit
Editing Step 5 —
Step Type:
Drag to rearrange
The power supply is attached to the upper case half with one 5.38 mm Phillips screw.
Use a #1 Phillips screwdriver to remove the screw and then remove the power supply.
Do not lose this screw. You will be using it to secure the new power supply to the upper case half.
