Help
Apple AirPort Express Base Station Power Supply Kit
Editing Step 32 —
Step Type:
Drag to rearrange
There are likely large burrs (shredded plastic bits) on the edges of your case from cutting it open. For ease of joining the case halves, it is recommended that you smooth the edges by de-burring them. A dremel tool with a sanding bit, a sanding block, or a knife will work for this process.
