Help
Apple Extended Keyboard II Teardown
Editing Step 8 —
Step Type:
Drag to rearrange
Remove the spring bar from the foot.
Release three sets of clips from the foot by pressing outward while lifting up. The back will need to be bowed out in order to remove the larger bump used as a control switch in the center.
It is very easy to break a tab - I had a casualty doing this teardown :[
Lift the foot up and away from the case. It should easily separate into two parts.
