Game Console Tools and Toolkits - Page 2
Products
59 results
Probe and Pick Set
Probe and Pick Set
Picks for for soldering work, poking, prying, scraping, scratching and o-ring removal.
Number of reviews:127
Lifetime Guarantee
$6.99
Suction Handle
Suction Handle
45 mm diameter suction cup is a necessary tool for opening iPhones, tablets, and other devices.
Number of reviews:205
Lifetime Guarantee
$2.99
Heat Gun
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).
Number of reviews:134
Lifetime Guarantee
$24.99
FixHub | Power Series Portable Soldering Station
The FixHub Portable Soldering Station gives you the power of a benchtop setup, anywhere you need it—without compromising performance. Whether you're in the workshop or out in the field, you're always ready to fix.
Number of reviews:19
$249.95
Phillips #00 Screwdriver
Precision fixed blade screwdriver engineered by iFixit.
Number of reviews:184
Lifetime Guarantee
$5.49
Metal Spudger
Metal Spudger
Dual tipped metal spudger for more powerful prying, scraping, probing, and poking action. Perfect tool for opening an iPod or iPhone.
Number of reviews:176
Lifetime Guarantee
$2.99
TR8 Torx Security Screwdriver
Compatible with both T8 and T8 Security fasteners (TR8). Precision fixed blade screwdriver engineered by iFixit.
Number of reviews:118
Lifetime Guarantee
$5.99
Tri-point Y00 Screwdriver
Number of reviews:74
Lifetime Guarantee
$5.99
Tri-point Y1 Screwdriver
Three pointed screwdriver. Fits many tamper-proof three pointed fastener heads, including those found on MacBook Pro batteries. Similar to, and acceptable replacement for, Apple Tool 922-8991. Swivel top handle with precision tip driver.
Number of reviews:69
Lifetime Guarantee
$5.49
Phillips #0 Screwdriver
Precision fixed blade Standard Phillips screwdriver used to take apart laptops. Engineered by iFixit.
Number of reviews:60
Lifetime Guarantee
$5.49
Heavy-Duty Spudger
Heavy-Duty Spudger
Thicker and tougher than a standard spudger. Use this antistatic tool for working on electronic devices and DIY electronic repair.
Number of reviews:83
Lifetime Guarantee
Phillips #000 Screwdriver
Number of reviews:57
Lifetime Guarantee
$5.49
Electronics Cleaning Bundle
Bust through the dust with our Electronics Cleaning Bundle. Keep the insides and outsides of your electronics spotless with this collection of cleaning, brushing, and maintenance tools.
Number of reviews:55
$23.99
Phillips #1 Screwdriver
Number of reviews:43
Lifetime Guarantee
$5.49
T6 Torx Screwdriver
T6 Torx Screwdriver
Use to take apart and repair your computer. Swivel top handle with precision tip driver.
Number of reviews:40
Lifetime Guarantee
$9.99
TR9 Torx Security Screwdriver
Precision fixed blade screwdriver engineered by iFixit. Compatible with both standard and security torx.
Number of reviews:15
Lifetime Guarantee
$5.99
Tri-point Y0 Screwdriver
Similar to a Phillips, but with 3 blades. Precision fixed blade screwdriver engineered by iFixit.
Number of reviews:54
Lifetime Guarantee
$5.49
Xbox 360 Opening Tool
Used to open the plastic outer casing of the Xbox 360. Includes Security T8 and Security T10 combination key.
Number of reviews:23
Lifetime Guarantee
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
Number of reviews:121
$9.99
Made by iFixit
Designed in California using data from thousands of teardowns and repair guides, our tools set the industry standard for electronics repair. Whatever you need to open, repair, and reassemble your tech, we’re designing it in-house, with electronics-specific repair in mind.
Quality Guaranteed
We've spent more than a decade vetting sources and suppliers, and all of our parts and tools are backed by our quality guarantee.
Learn More
