GE Stove/Range/Oven/Cooktop Troubleshooting: Fix Common Problems
The first step towards a working GE Stove/Range/Oven/Cooktop is identifying the problem. Select one of our preferred guides below to diagnose and solve GE Stove/Range/Oven/Cooktop common issues.
GE Oven F0 Code
Is your GE Oven's display showing an F0 code? This indicates a failure in the controls. Let's look at how to check it and proceed.
GE Oven F2 (or F20) Code
This code says things are too hot in the oven. Let's get you cooled down and cooking.
GE Oven F4 Code
Your GE Oven is displaying an error code, and you need to get baking again. Let's look at these fixes to help you get going.
GE Oven F7 Code
Your GE oven is showing an F7 error. It likely isn't operating reliably. Let's see if we can get you cooking again.
GE Oven F8, F8X or F8XX Code
This page deals with GE ovens or Ranges that display the F8, F8X or F8XX codes where X stands for a number from 0-9.
GE Oven Bad Line Code
This code indicates that one leg of the 240V supply to an electric oven or range is absent.
GE Oven F1 Code
Your GE (or Kenmore with a model number beginning with 911.) oven is displaying the F1 Error Code. What's that about? Let's get you cooking again.
GE Oven Stove Range Error Code Retrieval
Your GE Oven, Stove or Range has stopped working. You need to get to the error code to determine what may be wrong. Here are some ways to access the codes.
GE Oven F3 Code
Your GE Oven displays the F3 code and refuses to work or shuts down. Let's explore possible solutions.
GE Oven F5 Code
This code indicates a problem with the Electronic Range Control/Electronic Oven Control (ERC/EOC).
Related Oven/Stove/Range Problems
Gas Stove Clicking But Not Lighting
Is your gas stove not lighting, but sparking and clicking? Follow these fixes and ignite your flame.
Electric Stove Burner Not Working
Will your electric stove refuse to turn on after turning the knob. Are all the burners dead, or just some? Follow these fixes and get cooking again.
Oven Not Turning On
Will your oven not turn on? Perhaps the broil element works, but the bake doesn't? Follow the fixes below and get your oven cooking again.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Ge monogram oven problem
Ge monogram oven, replaced probe and probe light still blinks on and o
GE Double Oven light (bottom) not working, main board bad.
Touch screen not working
