Microsoft Tablet Troubleshooting: Fix Common Problems
The first step towards a working Microsoft Tablet is identifying the problem. Select one of our preferred guides below to diagnose and solve Microsoft Tablet common issues.
Microsoft Surface Tablet Black Screen
Is your Surface on, but you can't see anything on screen? Can you log in, but you only get a cursor and nothing else? Have a look at these solutions!
Microsoft Surface Tablet Overheating
Is your Surface tablet getting too warm to touch? Are you getting warnings or a thermometer icon onscreen? Have a look at these solutions!
Microsoft Surface Tablet Not Charging
Is your Surface refusing to charge? Is it giving a Slow Charge warning? Does the battery drain even when you're connected to power? Give these fixes a try!
Microsoft Surface Tablet Will Not Turn On
Is your Surface Tablet failing to turn on? Are you getting a blank screen with no signs of life? Keep reading for some typical fixes!
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Surface Tcon Device cannot start (STATUS_DEVICE_POWER_FAILURE)
Microsoft Surface Pro 5
I would like to know the location of bios chip
Pro 5 1796 not detecting new battery.
Surface Pro 5 3rd touch failure. Screen replacement didn't fix the los
Do I need to change wifi antenna assembly?
Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)
Red screen after change display
Surface only works when plugged in after battery replacement?
