Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Keyboard Unable to Function Correctly
The computer does not recognize input from the keyboard.
Keyboard Contaminated
Sometimes accidents happen and liquids and foods enter the keyboard. The initial step is to blow off the keyboard by tilting to one side and spray with a can of compressed air starting at the top of the tilt and working your way down. If liquids were present leave system powered down and allow 24hours to dry in a damp free place.
Keyboard Keys Missing/Broken
Additionally the keys may no longer work due to normal use. If liquids were present the keyboard hardware may have shorted out while the computer was running. If the keyboard does not respond after cleaning then replace the keyboard using this guide.
Computer Will Not Power On
The computer does not respond at all to powering up sequence.
Faulty Power Adapter
Their are 2 components that can cause a faulty power supply which will not let the computer boot. The first component to check is the 2 cords one that connects to the wall and adapter to computer. These cables can be easily damaged through normal use. If the cords does not fix the issue then replace the power block with one matching the specification located on the power block.
Faulty Battery
If the power adapter is plugged in both to the wall and the computer, and the indicator light on the power supply block is on. The computer starts when the adapter is plugged in however does not start up when just the battery is present then the battery is faulty. Replace the battery using this guide.
Computer Will Not Boot
The Operating System does not load and displays an error message screen.
Faulty RAM
If your computer runs slowly or frequently crashes during normal operation, fails during memory intensive tasks, or issues audible beeps during boot up sequence, this means either the amount or RAM is insufficient or a stick(s) of RAM went bad. Install additional RAM or replace defective RAM using this guide.
Faulty Hard Drive
The hard drive in the computer may have an error(s) on it. One cause of this can be improper “forced” shutdown usually involving holding the power button for 5 seconds or more, as well as power outages. If this does not resolve booting issues you may need to replace the hard drive following this guide.
Laptop Overheats
While the computer is running, your computer shuts down without any notification.
CPU Heat-sink/Fan Dirty
In normal operation the CPU fan blows air through a heat-sink for system cooling. Depending upon the environment in which it operates dictates how often these items require cleaning. To clean both the fan and heat-sink used canned compressed air first starting with the fan the work your way to the heat sink.
Faulty CPU Thermal Paste
Your computer may not have solid contact between the CPU and the heat sink fan assembly. The cause of this is usually by a lack of thermal paste due to age and temperature exposure or by air between components. Replace the existing thermal paste with this guide.
Jason Hofstetter
11 Reputation
0 Guides authored
USF Tampa, Team 3-2, Brown Fall 2014 Member of USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Members
27 Guides authored
3 Comments
Headings should be formatted so that the top level is the problem and the second level is a possible cause. So, instead of "Clean or Replace Keyboard" a more appropriate second-level heading would be "Keyboard is Broken or Dirty."
Dan Brown - Reply
Also, "Unable to Login" could be a software problem. Try to phrase headings as hardware problems.
Dan Brown - Reply
The content for cleaning the keyboard should be broken up into separate sections.
Dan Brown - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 435
