Repair information and guides for MacBook Pro models with 13" displays.
Converting MacBook Pro to windows os
Hi,
I have a MacBook Pro 2012 (not retina) i5, I recently loaded Chrome OS Flex onto it for family but now need a Windows OS. Can I somehow now load Windows, what would be the best process, is it practical/ worth it?
Any advice would be greatly appreciated.
1 Comment
Thank you very much, I also managed to get Mac OS back on by holding cmd + option +R, so process started, thanks again.
by
Add a comment
1 Answer
Chosen Solution
It is definitely doable to get Windows 10 running on your Macbook! I've found this video that should guide you through the process: https://www.youtube.com/watch?v=fSIYDlTx...
I would also take note that the i5 models have 4GB of RAM included, which while it will still be able to run Windows 10, it will not be pleasant. So I would advise doing a RAM upgrade to if you plan to do so, a tutorial on how to do such an upgrade can be found here: MacBook Pro 13" Unibody Mid 2012 RAM Replacement and a good resource that should give you all the resources to do an upgrade to 16GB of RAM can be found here: MacBook Pro 13" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit
Max your MacBook Pro 13" Unibody Mid 2012 with 16 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your laptop. Compatible with 2.5 or 2.9 GHz Mid 2012 MacBook Pros. Image
Product
$139.99
Score 1
1 Comment:
Here is one for Windows 11 without Bootcamp https://www.youtube.com/watch?v=flxXlArD... a bit tricky but it works a treat. But I definitely recommend at least 8 GB RAM and a decent 500 GB SSD to make it run nicely. Crucial, Samsung, PNY or ADATA are reliable makes.
by
Add a comment
Add your answer
DPS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 124
