Troubleshooting
For additional help with the Hover-1 Eagle, check out the device's troubleshooting page.
Background and Identification
The Hover-1 Eagle Scooter is an electric scooter that was released in 2019. With the lightweight chassis of 20 pounds and collapsible handlebar, the Hover-1 Eagle was designed with portability in mind.
This electric scooter tops out at 15 miles per hour with a 7 mile distance range per charge. The handlebars house an electronic throttle, a LED speedometer, and a LED headlight. The handlebar also internally houses the battery pack with a 4Ah capacity. The base of the electric scooter is where both 6.5 inch wheels are mounted to, and where the braking pad is placed.
Hover-1 has released similar models to the Eagle, but this model can be easily identified by its large blue cross on the deck.
Specifications
  • Dimensions: 15.75 in x 45.75 in x 37.50 in
  • Weight: 20.88 lbs
  • Battery Capacity: 36V, 4.0 Ah, with overcharge and discharge protection
  • Weight Capacity: 264 lbs
  • Wheel Diameter: 6.5 in
  • Miscellaneous: Front Wheel Drive, LED headlight, Electronic throttle and foot brake, App connectivity with learning modes, 5-hour max charge time
Additional Information
Hover-1 Eagle Troubleshooting Page
Hover-1 Eagle Manual
Walmart Product Page
Hector Delgado
51 Reputation
0 Guides authored
Cal Poly, Team S1-G2, White Winter 2020 Member of Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Members
6 Guides authored
Past 24 Hours: 5
Past 7 Days: 61
Past 30 Days: 321
All Time: 18,564
