Help
iBook G4 14" 933 MHz-1.33 GHz Upper Case Replacement
Editing Step 1 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 20 guides that include this step.
Step Type:
Drag to rearrange
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 11 mm Phillips in the lower right corner. (if present)
Four 14.5 mm Phillips.
