Help
iBook G4 14" 933 MHz-1.33 GHz Upper Case Replacement
Editing Step 3 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 20 guides that include this step.
Step Type:
Drag to rearrange
Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
