Help
iBook G4 14" 933 MHz-1.33 GHz Upper Case Replacement
Editing Step 5 —
Notice: You are editing a prerequisite guide. Any changes you make will affect all 20 guides that include this step.
Step Type:
Drag to rearrange
The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
