Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Sound or Poor Sound Output
No sound can be heard from the turntable when a record is playing.
Broken/Missing Output Device
Try connecting the turntable to a different speaker or switch the output mode from wired to Bluetooth or vice versa.
Dirty Turntable Components
In case of static, crackling, or popping, check the cleanliness of the record or stylus, or check if there are any scratches on the record.
If there is feedback, ground noise, or distortion, make sure that your record player is on a flat, clean surface, away from any sources of static or vibrations.
Broken Needle Cartridge
The turntable's needle may be broken or defective. Replace the needle cartridge using this replacement guide.
Broken Platter
The platter holds the vinyl in place and can affect the sound quality as a result. If the platter is loose or defective, replace it using this replacement guide.
Tone Arm Does Not Raise or Lower
The lever no longer lifts or lowers the arm holding the stylus.
Defective Lever
If the tone arm does not raise or lower, the lever mechanism may be defective or damaged. Replace the lever mechanism using this replacement guide.
No Change in Volume Level
There is sound playing, but the volume knob has no effect.
Broken Volume Knob
If the volume knob does not change the volume of the sound output when turned, the volume knob may be broken, loose, or defective. Replace the volume knob using this replacement guide.
Device Will Not Power On
The device is plugged in, but no lights or electronics are visibly on.
Broken Power Cord
The power adapter is likely defective or damaged. You will have to purchase another power adapter with a 3.5mm 5V DC connector.
Turntable Spins Too Fast or Too Slow
The platter is spinning, but at inconsistent speeds or pitches.
Broken Belt
If the turntable is spinning at an inconsistent speed, the belt is likely broken or defective. Replace the belt using this replacement guide.
Turntable Does Not Spin When Device Is On
The turntable is on, but the motor isn't spinning.
Broken Motor
If the turntable is not spinning when the device is powered on, the motor is likely broken or defective. Replace the motor using this replacement guide.
0 Comments
