Camera will not turn on
No matter what you do, you can't get your Camera to turn on.
Dial on wrong setting
Before taking everything apart, make sure that the settings dial is not turned to the 'OFF' position (red L). If your camera problem isn't so easily solved, read on.
Drained battery
If you have not used your camera for a while, it is possible that your batteries are drained. This is an easy fix however, you might need to change your batteries.
Bad logic board
If camera continues to not turn on, even with new batteries, the problem might be in your logic board. We offer instructions for installing the logic board in your camera.
Film will not roll
When taking photos your film is not rolling.
Back latch broken
If the back door of your camera does not fully close, the camera will not roll film. You might need to replace your back door latch, which we offer a guide for here.
Winding mechanism broken
If your film roller is not working it could be an issue with the winding mechanism in the camera. We unfortunately do not have a guide for this problem at this time.
Flash bulb will not work/deploy
Flash is not deploying when it is activated, or flash is deploying but does not go off.
Bad logic board
If the flash bulb does not deploy or go off, there may be a bad connection to the logic board. Refer to the logic board guide for repair instructions.
Broken/burnt out bulb
If the flash bulb is deploying but not going off, the bulb may be broken or burnt out. We offer instructions on how to install a new bulb into your camera.
LCD screen will not work
Your camera turns on but your screen does not display anything.
Bad logic board
If the LCD screen does not display, there may be a bad connection to the logic board. Refer to the logic board guide for repair instructions.
Bad LCD display
If the connection to the motherboard is good, there might be a problem with the LCD display itself. We offer instructions on how to install a new LCD display into your camera.
Lens will not attach properly
Camera lens does not lock in place when attached to the camera.
Lens connector broken
If the camera lens will not attach properly to the camera, you might have a broken lens connector. You can find instructions on how to replace the lens connector here.
Locking pin not securing lens
If the lens connector is intact, there may be a problem with the locking pin for the lens. We unfortunately do not have a guide for this problem at this time.
Lens itself could be damaged
If the lens connector and locking pin are both working, your lens itself may be damaged. We unfortunately do not offer a repair guide for lenses at this time.
9 Comments
My camera turns on, displays full battery (batteries are new) until I press the button to take a picture - then it switches to "change battery". I have made sure batteries are good. There is no corrosion in the chamber. Any guesses?
billbeccajanes - Reply Share
Did you ever find a solution? I have that problem as well.
Chandra Ramey - Share
I have the same issue as well. Once you turn the camera off and back on again it returns to full battery. Have found no solution anywhere…
Cam Bush - Share
Yep, same issue. The troubleshooting section of the manual simply says “camera not functioning properly” yeet
Noah Smith - Share
I am having the same issue with mine. I find that if I switch out of M to another mode, it comes back again. It seems to be struggling to advance the film? I took the film out and reloaded but that didn't fix the issue.
Has anyone found a resolution to this yet?
Therese Kirchner - Share
