Brand new heatsink laptop fan not working.
I've been trying to fix my old laptop for a while now. Recently, my new replacement fan came in for the MSI CX62 6QD, it is the same model from the same company (AAVID THERMALLOY PAAD06015SL). However, when I plug the fan in, it doesn't work. Turning on my computer makes the fan shake slightly, but then it doesn't move after that. I recently put a new hard drive into the laptop so there isn't any OS yet. Could that be the reason the fan isn't spinning yet?
However, my old laptop fan spins when I turn it on, so could it be a manufacturing error?
The new fan power connector is black instead of white for some reason, but they look identical apart from that.
Edit:
Here are the images of my old fan and my new fan:
On the left, is the new one and on the right is the old one.
Edit 2: Closeups of the white connector, front and back. (Sorry I wasn't exactly sure what you meant by this but I hope this is what you're looking for)
9 Comments
What voltage does the fan run at?
by Andrew S
0.55 Volts :)
by ✧Andi ԑ̮̑ঙ¸
@dacelynn your voltage should be 5V and 0.5A
by oldturkey03
Oh sorry, I read it wrong, it is 0.55A and 5V, however, the new fan does not have information on an 'nxxx' number.
by ✧Andi ԑ̮̑ঙ¸
@dacelynn my concern is that you have either a wrong fan or a bad fan since you ssaid your old fan works in your computer. Post an image of your fans with your Question. Let's see what you got there. Adding images to an existing question
by oldturkey03
Show 4 more comments
